shape for 4 by 4 grid
trilogy
Postby trilogy » 27 Aug 2009, 22:47
Hi i have a 4 by 4 grid of led cans. i want to do a rainbow shape from top left to bott right changing by diagonal rows . i'm using a tiger is there a way to do this?
TL x x x
x x x x
x x x x
x x x BR
Postby niclights » 27 Aug 2009, 23:30
Shapes will use fixture selection order when applying offset (spread).
For example, try selecting in this order:
1  3  6 10
2  5  9 13
4  8 12 15
7 11 14 16
and apply a rainbow with a spread of 8 fixtures or so.
Unfortunately in classic software there is no way to set more than one fixture to a particular fixture order step, so this is probably as close as you will get.
(iCe)
Postby (iCe) » 30 Aug 2009, 11:59
I use the selection order all the time, also for pan/tilt effects. Most of the times that's a faster way of creating a random looking saw then having to play around with the fine/course parameters.
In a small matrix this will probably acheive the effect you want, in a larger one I don't think you'll be that pleased since you'll see the offset running in each cross diagonal line too (which you don't want I guess).
Is such a thing possible (or going to be possible) in Titan?
Postby niclights » 30 Aug 2009, 14:44
(iCe) wrote:Is such a thing possible (or going to be possible) in Titan?
Yes, because you can set more than one fixture per order step. Additionally have the option to use fixture overlap function in chases instead of shapes and this also uses fixture order.
(iCe)
Postby (iCe) » 31 Aug 2009, 20:48
Already possible or yet to come? I wouldn't exactly know how to do this right now.
Postby niclights » 01 Sep 2009, 01:50
Already possible. Edit Times/Fixture Order. Enter step number and then select fixtures for that step. See manual p.60.
Postby niclights » 01 Sep 2009, 17:45
Ah, my apologies. Unfortunately it seems this does not quite work for shapes. Fixture order for the playback and for the shapes are seen as separate and there appears to be no way at the moment to edit the shape order after it has been stored. There is also no way to set multiple fixtures per order step before storing.
However, it is possible to do this by manually editing the showfile if you really need it.
(iCe)
Postby (iCe) » 03 Sep 2009, 20:18
Would be a nice feature though :)
Postby niclights » 03 Sep 2009, 20:50
For sure. The function's there, it just needs user interface. Hopefully this will be an option soon. I've added to my requests list.
Users browsing this forum: Baidu [Spider], Google [Bot] and 56 guests
