Titan wishlist
Braathe
Titan wishlist
Postby Braathe » 28 Jul 2009, 15:06
A few features I would like to see implemented in Titan
Option to set chase direction to random, It can be a pain to make a 200 step chase to get a proper random feel to it.
Wheel acceleration on shape time, chase speed, etc. Either by holding down AVO-key or by speed up after a set amount of spin time.
Random dimmer shape, I do not know if this is possible with the way the shapes work ?
A wish I had from a external technician was the option to "flash" a palette.
So If one hold down a palette button for more than one sec or so it would release and go back to the state before the palette button was pressed.
This could come in pretty handy when busking.
-BÃ¥rd
Re: Titan wishlist
Postby niclights » 28 Jul 2009, 19:14
Braathe wrote:Option to set chase direction to random, It can be a pain to make a 200 step chase to get a proper random feel to it.
Can you not already do this with the review key? If not then it is definitely available via show library. IIRC there is a random tick box as well as random in the play order drop down list. I don't think anyone knows why there are two settings for this!
Braathe
Postby Braathe » 28 Jul 2009, 21:12
There is ? IIRC the manual do not mention anything of it. I will give it a go tomorrow, but i guess your right about what your saying :)
Braathe
Postby Braathe » 29 Jul 2009, 12:46
My bad on this one, for some reason i had totally overlooked it. Playback options and a few clicks solved it.
Postby niclights » 29 Jul 2009, 14:12
Are you sure you can't access this directly with the review key (while connected)? The chase control keys should give access to all play orders including random allowing you to change this quickly.
ChiekuRs
Postby ChiekuRs » 14 Aug 2009, 15:23
It would be very nice if you could switch to pearl classic without external screen.
(iCe)
Postby (iCe) » 14 Aug 2009, 23:32
ChiekuRs wrote:It would be very nice if you could switch to pearl classic without external screen.
I very much agree on this one!
ChiekuRs
Postby ChiekuRs » 19 Aug 2009, 20:51
Fixture LEDs Show Occupation feature is very nice when patching, but in my opinion, LEDs are bit to bright for programming and sometimes it's hard to see which fixtures are selected.
Best solution would be to add posibility to adjust LED brightnes for un-selected fixtures, but easy one would be to add 3rd option in user settings that disables this feature - "Show Occupation", "Mimic Intensity" or "Show Selection".
majo
Postby majo » 09 Oct 2009, 11:19
Is possible to link Palette to other Fixture page?
Olie
Site Admin
Postby Olie » 09 Oct 2009, 17:43
This is in version 2 :-)
This is impossible to do as the application which controls the LCD screen and buttons is the application you need to switch. We also state that you should never use the console without an external VDU. Not having a VDU means you might miss important information.
Re: Titan wishlist
Postby niclights » 09 Oct 2009, 17:56
Braathe wrote:Wheel acceleration on shape time, chase speed, etc. Either by holding down AVO-key or by speed up after a set amount of spin time.
-BÃ¥rd
And while we're at it, this is in v2 also.
JTL
Postby JTL » 19 Nov 2009, 21:35
would be great to see a Generic Macro Editor, like in Martin LJ.
The ability to lay generic shapes (sine, steps etc) over specific channels, and have control over the offset, intensity, direction, timing.
Also the ONE thing that would be really helpfull to see would be a 'Random' direction option for the shape generator. To achieve random strobe effects etc. Or if there is already a way-around, i'd love to know about it!
J
SL
Postby SL » 22 Nov 2009, 11:58
I think it`s great when you can set 'followtimes' in a cuelist. That you can start cue 1, and cue 2 starts after 3 seconds, without pushing any buttons.
And when you set fixture order in a cuelist, i can`t deselect the fixture who is already in the automatic fixture order?
Postby niclights » 22 Nov 2009, 12:19
For 'followtimes' can you not use link?
I'm not sure I understand what you mean about fixture order.
SL
Postby SL » 23 Nov 2009, 07:01
Can you explain what you mean with link, or give me a page number from the manual where i can read it.
Fixture order in a cuelist. When i set fixture overlap at 30% or so, then is the fixture order in the order where i`ve selected all the fixtures in that group. When i wanna have an other order, i can`t deselect the fixture who`s already in the order.
Hopefully it`s clear so?
