Capture Visualiser
watty
Capture Visualiser
Postby watty » 18 Jan 2018, 14:21
Is it possible to view a running playback or whole running show in Capture Visualiser?
Re: Capture Visualiser
Postby Gregory » 18 Jan 2018, 14:28
The internal Capture Visualiser will display the whole running show. If you are in blind mode it will additionally show the contents of the blind programmer and any playbacks set to blind however it will still show the live output as well.
watty
Postby watty » 22 Jan 2018, 14:06
Thanks for the reply. Please can you explain how to see a running playback or show in Capture Visualiser? If I open Capture Visualiser I can see the contents of the programmer in Visualiser, However, when I run a show nothing appears. Am I missing something here - should it automatically show the output of the console or are there any settings which may cause it not to work?
watty
Postby watty » 23 Jan 2018, 12:59
Does anyone have any thoughts?
Postby niclights » 23 Jan 2018, 13:02
I'm just going to have to say it:
Is the grand master (or, similarly, playback master or group master) at zero?
watty
Postby watty » 23 Jan 2018, 19:00
Thanks Nick for the suggestion - all comments gratefully received. Maybe it was :? I spent a lot of time on the console (Titan Mobile) a week or so back setting up fixtures in Visualiser until late into the night and could not see any playbacks - I may well have set a master at zero without realising :roll: Just switched it on to check settings and all is well :D
oaksld
Postby oaksld » 25 Jan 2018, 14:33
In DMX settings make sure that Visualser output is turned on.
Postby niclights » 25 Jan 2018, 15:47
oaksld wrote:In DMX settings make sure that Visualser output is turned on.
In this case the programmer output would not work either.
