values ​​of some projectors at 100% at the start of the show
Bhouck8
Postby Bhouck8 » 03 Oct 2025, 13:27
Hello everyone, I've been an Avolites console operator for 8 years, and I have a blast with these consoles. I frequently work at the Cadre Noir in Saumur, France, which houses a Sapphire Touch.
On the show created by the venue manager, when he launches it, some values ​​aren't at zero (some panels are at 100%, and the smoke machine is at 30%). However, no cues are launched, no macros, and the programmer is empty. To turn them off, simply set their dimmer to zero. But every time he restarts his show, the values ​​return. And I just had the same problem: by changing the personality for the smoke machine, now when I launch my show, the smoke machine is at 30% (the value I had set on a fader). I've tried deleting all the cues, emptying the faders, deleting the macros, and even completely emptying the smoke intensity, but it's still at 30%. I also tried patching the smoke machine without results. The problem is not a serious one, but I would like to find a way to eliminate this defect. Many thanks in advance to anyone who wants to look into it. Have a good day everyone, and I look forward to seeing you at a performance.
Re: values ​​of some projectors at 100% at the start of the show
Postby icke_siegen » 07 Oct 2025, 14:32
Hard to tell without having a look at your show. You may open a ticket at the helpdesk at https://web3.avolites.com/software/help-desk, send the show and provide the details which you already mentioned. if you want you can be in touch with me at sebastian.beutel@avolites.com.
Bhouck8
Postby Bhouck8 » 14 Oct 2025, 20:07
Hello Sebastian, thank you very much for your interest in my problem. I've created a ticket to follow up, and I've also sent you the drive-through link to the show I mentioned (it's too large to send as an attachment). Thank you again, and best wishes.
Alexandre Milcent
Postby icke_siegen » 15 Oct 2025, 07:08
i have already answered directly. It looks like you have set a release state which puts the dimmers at full. See https://manual.avolites.com/docs/cues/c ... r-on-state of how this is done.
In order to fix this:
  • <Clear>
  • select one (or more) SOLAR27Q
  • set the dimmer to 0%
  • <RECORD>
  • <OFF>
  • [Shared Values] (you don't need to click this, this should already be set)
  • [Record]
  • <CLEAR>
