Hello everyone, I've been an Avolites console operator for 8 years, and I have a blast with these consoles. I frequently work at the Cadre Noir in Saumur, France, which houses a Sapphire Touch.
On the show created by the venue manager, when he launches it, some values aren't at zero (some panels are at 100%, and the smoke machine is at 30%). However, no cues are launched, no macros, and the programmer is empty. To turn them off, simply set their dimmer to zero. But every time he restarts his show, the values return. And I just had the same problem: by changing the personality for the smoke machine, now when I launch my show, the smoke machine is at 30% (the value I had set on a fader). I've tried deleting all the cues, emptying the faders, deleting the macros, and even completely emptying the smoke intensity, but it's still at 30%. I also tried patching the smoke machine without results. The problem is not a serious one, but I would like to find a way to eliminate this defect. Many thanks in advance to anyone who wants to look into it. Have a good day everyone, and I look forward to seeing you at a performance.
values of some projectors at 100% at the start of the show
Re: values of some projectors at 100% at the start of the show
Hard to tell without having a look at your show. You may open a ticket at the helpdesk at https://web3.avolites.com/software/help-desk, send the show and provide the details which you already mentioned. if you want you can be in touch with me at sebastian.beutel@avolites.com.
Hello Sebastian, thank you very much for your interest in my problem. I've created a ticket to follow up, and I've also sent you the drive-through link to the show I mentioned (it's too large to send as an attachment). Thank you again, and best wishes.
Alexandre Milcent
Alexandre Milcent
i have already answered directly. It looks like you have set a release state which puts the dimmers at full. See https://manual.avolites.com/docs/cues/c ... r-on-state of how this is done.
In order to fix this:
- <Clear>
- select one (or more) SOLAR27Q
- set the dimmer to 0%
- <RECORD>
- <OFF>
- [Shared Values] (you don't need to click this, this should already be set)
- [Record]
- <CLEAR>
