2004 1.2VER question?
xeonwzh
Postby xeonwzh » 26 Nov 2006, 13:17
I have upgranded my console to 1.2 editions,but I find,RUN mode is alittle unusual,I have done dozens of pieces of localization light,using the program mode to be noramal when used,when I use RUN mode,I click the blue SWOP key,then push to FADE,my localization light is all messy,What reason? :oops:
Postby niclights » 26 Nov 2006, 13:55
Can you try and explain differently?
Which Swop buttons and what do you expect them to do?
xeonwzh
Postby xeonwzh » 26 Nov 2006, 15:05
The blue SWOP key uses and dones not let the light be put in place first all on 15 FADEs.
Postby niclights » 26 Nov 2006, 23:24
I'm very sorry but I cannot understand you.
There are Playback SWOP keys that either 'solo' that playback (Run Mode Normal) or can be used for filtered palettes (Run Mode Takeover).
There are Preset SWOP keys that either 'solo' the preset handle (Run Mode Normal) or select fixtures (Run Mode Takeover).
Can you explain whether it is Preset or Playback and whether Normal or Takeover mode?
Also can you explain exactly what you mean by 'messy'?
xeonwzh
Postby xeonwzh » 28 Nov 2006, 14:27
What I used under RUN MODE is TAKEOVR, messy behavior, for example I make one mere 3 light by fixed position, I way run good in PROGRAM MODE, turning into RUN MODE, after using PLAYBACK SWOP button, 2 light are normal, 1 light has deviated from the position, has not used any PRESET in this course
Postby niclights » 29 Nov 2006, 00:27
Hmmm. I don't see how that can happen.
A different question:
What do you expect to happen when you press Playback SWOP in Run Takeover Mode?
or:
Why are you pressing Playback SWOP?
Sorry for the questions. Translation is difficult to understand but will keep trying to solve your problem :)
xeonwzh
Postby xeonwzh » 29 Nov 2006, 16:35
Maybe me it is not good that the language is expressed
1:CUE runs well in the programm mode
2:I hope to playback under RUN MODE,The SWOP key on PLAYBACK can reservation pan&tilt positon and not bright,The result is that the position of an specific light is wrong,but ,normal in the programming mode
3:The RUN mode uses TAKEOVER
thank you
Postby niclights » 30 Nov 2006, 01:14
It is clear that you seem to be having pan/tilt problems when using Swop in Takeover mode, but I still do not understand why you are pressing the Swop button!
What are you expecting it to do? I need to understand this first.
In Program mode it is used to select playbacks for recording or deleting memories, chases or shapes and for unfolding chases. It is also used as 'destination' when copying or photocopying.
In Takeover mode it is only used for 'filtered palettes'.
In both modes it is used for 'connecting' a chase.
xeonwzh
Postby xeonwzh » 30 Nov 2006, 12:46
I am sorry, I find that you are testing my English level , I am very in pain
xeonwzh
Postby xeonwzh » 30 Nov 2006, 12:53
Do not I know what is name you playback fade to on that blue button of the clipper above ?
Postby niclights » 30 Nov 2006, 14:44
We will get there eventually :)
Blue button = Swop, yes.
But why are you pressing? What you expect it to do?
xeonwzh
Postby xeonwzh » 01 Dec 2006, 13:37
Use the SWOP key of PLAYBACK under RUN MODE, I want to make LTP CHANNEL of the lights all carry out and the light is not bright, wait for me to push FADE of PLAYBACK.
Present question is that a question of the FIXTURE is still a question of upgrading 1.2VER on earth
Postby niclights » 01 Dec 2006, 15:22
I'm so sorry but I still cannot understand.
Playback Swop in Run Takeover Mode is used for filtering palettes only. It has no other function.
I do not know of any such problems with this version.
What language do you speak? Can you write here in your language and maybe someone can kindly translate? Or do you know anyone that speaks English?
xeonwzh
Postby xeonwzh » 02 Dec 2006, 16:05
I an chinese.
我的语言你能看懂吗?
我的问题很简单,我升级了我的PEARL2004台子到1.2版本,现在出现我一些问题,当我在编程模式保存好的定位光,比如有3个灯,当我在运行模式,使用TAKEOVER的选项,我要使灯不开光先让灯走到预定的位置,这时我使用了返演推子上的蓝色SWOP键,但是当我推上返演推子的时候,有一个灯没有走到保存的位置,但是,返回编程模式在推返演推子就是正常的,不知道是灯具的问题还是升级了1.2版本的问题?
Are you understand?
Postby niclights » 02 Dec 2006, 17:18
Hi.
I will try to get person to translate.
While waiting can you write to Avolites Distribution China?
dave@leifull.com (Dave Chou)
or
dne@dnein.com.hk (Philip Wong)
If they cannot answer question perhaps they can translate and post here?
