2004 1.2VER question?
I have upgranded my console to 1.2 editions,but I find,RUN mode is alittle unusual,I have done dozens of pieces of localization light,using the program mode to be noramal when used,when I use RUN mode,I click the blue SWOP key,then push to FADE,my localization light is all messy,What reason?
I'm very sorry but I cannot understand you.
There are Playback SWOP keys that either 'solo' that playback (Run Mode Normal) or can be used for filtered palettes (Run Mode Takeover).
There are Preset SWOP keys that either 'solo' the preset handle (Run Mode Normal) or select fixtures (Run Mode Takeover).
Can you explain whether it is Preset or Playback and whether Normal or Takeover mode?
Also can you explain exactly what you mean by 'messy'?
Maybe me it is not good that the language is expressed
1:CUE runs well in the programm mode
2:I hope to playback under RUN MODE,The SWOP key on PLAYBACK can reservation pan&tilt positon and not bright,The result is that the position of an specific light is wrong,but ,normal in the programming mode
3:The RUN mode uses TAKEOVER
thank you
thank you
It is clear that you seem to be having pan/tilt problems when using Swop in Takeover mode, but I still do not understand why you are pressing the Swop button!
What are you expecting it to do? I need to understand this first.
In Program mode it is used to select playbacks for recording or deleting memories, chases or shapes and for unfolding chases. It is also used as 'destination' when copying or photocopying.
In Takeover mode it is only used for 'filtered palettes'.
In both modes it is used for 'connecting' a chase.
I'm so sorry but I still cannot understand.
Playback Swop in Run Takeover Mode is used for filtering palettes only. It has no other function.
I do not know of any such problems with this version.
What language do you speak? Can you write here in your language and maybe someone can kindly translate? Or do you know anyone that speaks English?
Hi.
I will try to get person to translate.
While waiting can you write to Avolites Distribution China?
dave@leifull.com (Dave Chou)
or
dne@dnein.com.hk (Philip Wong)
If they cannot answer question perhaps they can translate and post here?
or
Users browsing this forum: Bing [Bot] and 31 guests
