Set BPM Multiplier
sideshowbond
Set BPM Multiplier
Postby sideshowbond » 15 Apr 2019, 14:58
I'm trying to set BPM multipliers to specific values rather than use double or half.
Masters.SetSpeed
sets the multipler to some value when the master itself is set to 'multiplier on fader' but that doesn't really prove helpful as I set BPM via macro too.
There a way to make this work? Double or half don't always trigger cleanly the way I got my cuestacks set up.
Re: Set BPM Multiplier
Postby icke_siegen » 15 Apr 2019, 16:19
how about something like this:
ActionScript.SetProperty.Double("Masters.OptionsEditor.SingleSelection.SpeedMultiplier", Math.Cast.ToDouble(2.0));
sideshowbond
Postby sideshowbond » 15 Apr 2019, 16:54
does that double the value or set it fixed at 2?
Postby icke_siegen » 15 Apr 2019, 17:06
It sets it to 2. In order for other multipliers simply change
to
Math.Cast.ToDouble(0.25)
or
Math.Cast.ToDouble(4.0)
etc.
In order to select a master I'd try something like
ActionScript.SetProperty("Masters.SelectedMaster",handle)
Honestly this needs to be tried out...
sideshowbond
Postby sideshowbond » 15 Apr 2019, 17:08
I'll have a look at it tomorrow. I guess my problem lies a little with more than one macro attached to one cue plus link with previous cue which doesn't leave time between macros to be run.
Postby icke_siegen » 15 Apr 2019, 17:28
At the moment I am struggling to select the master: cannot convert string to handle...
sideshowbond
Postby sideshowbond » 15 Apr 2019, 17:34
I get
Unable to cast object of type 'System.Int32' to type 'Avolites.Titan.Controllers.Handles.Handle'
I'm using
ActionScript.SetProperty("Masters.SelectedMaster",1612)
Postby Gregory » 15 Apr 2019, 22:08
You need to use the string notation to specify the handle and cast it to a handle so that the SetProperty knows that is what you want.
ActionScript.SetProperty("Masters.SelectedMaster", handle:"masterHandleID=1612")
ActionScript.SetProperty.Double("Masters.OptionsEditor.SingleSelection.SpeedMultiplier", 2)
As you are using the SetProperty.Double function you do not have to cast the number, you could alternatively do this:
ActionScript.SetProperty("Masters.OptionsEditor.SingleSelection.SpeedMultiplier", double:2)
sideshowbond
Postby sideshowbond » 16 Apr 2019, 00:06
Brilliant, thank you both :)
