Shapes and effects sync fixtures
acetaxidriver
Postby acetaxidriver » 06 May 2018, 21:56
Hi.
I have 8 fixtures in a row and I apply a PAN/TILT SQUARE EFFECT;
For the fixtures 1,2,3 and 4 I select REVERSE SELECT FIXTURES and the group 1,2,3,4 is not symmetrical to group 5,6,7,8.
I have to try various values for PHASE OFFSET to get symmetrical effect.
Is a way to sync the group split ?
Using Titan 10.1
Re: Shapes and effects sync fixtures
Postby niclights » 07 May 2018, 18:21
Reverse and 180° phase offset.
acetaxidriver
Postby acetaxidriver » 07 May 2018, 18:30
Does not work. Still out of sync, at least using capture visualiser.
Postby niclights » 07 May 2018, 18:41
Works fine for me. If the shapes are in the programmer you might need to restart them after changing the phase offset ([Shapes And Effects]/[Shape Generator]/[Edit]/[Restart Shapes]).
acetaxidriver
Postby acetaxidriver » 07 May 2018, 18:51
SOLVED
In Capture visualiser they are out of sync, but after recording to a cue is OK.
Restarting shapes also works.
