Hi.
I have 8 fixtures in a row and I apply a PAN/TILT SQUARE EFFECT;
For the fixtures 1,2,3 and 4 I select REVERSE SELECT FIXTURES and the group 1,2,3,4 is not symmetrical to group 5,6,7,8.
I have to try various values for PHASE OFFSET to get symmetrical effect.
Is a way to sync the group split ?
Using Titan 10.1
Shapes and effects sync fixtures
acetaxidriver
Re: Shapes and effects sync fixtures
Reverse and 180° phase offset.
acetaxidriver
Does not work. Still out of sync, at least using capture visualiser.
Works fine for me. If the shapes are in the programmer you might need to restart them after changing the phase offset ([Shapes And Effects]/[Shape Generator]/[Edit]/[Restart Shapes]).
acetaxidriver
SOLVED
In Capture visualiser they are out of sync, but after recording to a cue is OK.
Restarting shapes also works.
