Avolites Pearl 2008 - URGENT! Color Palette problem!
SJPMC
Postby SJPMC » 26 Aug 2017, 12:34
I'm about to run a show and I'm farely new to Avolites, and we only use Beams and Wash's, the old LD had the board setup so that a color palette would change the color for either the Beam or Wash, the color values do not match so, I can't just select all fixtures and change the color wheel, how do I make this back to a palette affecting both fixture types color wise even though the color values dont matchup.
Sorry for the crude english but this is very urgent.
Re: Avolites Pearl 2008 - URGENT! Color Palette problem!
Postby niclights » 26 Aug 2017, 13:32
You should be able to record values for the two types of fixtures into the same palette. So select fixture type 1, set colour, record palette (double-tap to merge), select fixture type 2 and repeat.
SJPMC
Postby SJPMC » 27 Aug 2017, 14:17
Sorry, but I didn't understand the double tap part, so, I select fix1 set the color to , for instance, red, store the palette into a flash, than, select red on the other fixture and hit, store palette and doubletap the flash where the previous one was?
Postby niclights » 27 Aug 2017, 15:22
Yes. Sounds about right to me. Save the show if you're worried then try it. If there's a problem just reload the original show.
