Hey !!
Have problems with my new Martin Qvantum spot!!
Everything works perfekt but not TILT ! it just hacks !
Both in basic mode and extended mode
what can be wrong ??
need help urgently
Help.....,problem TILT
- Nicke Löfgren
Re: Help.....,problem TILT
If possible can you please provide more details? What exactly do you mean by hack?
Does enabling 'P/T Smooth' help?
- Nicke Löfgren
Pan works perfekt when i rotates the wheel
When I do the same thing on tilt so moving armature not neat, more jerky / jump
Has tested the P / T speed, the same error
the problem is not in the luminaire, all have the same problem
I think it can be the personlty file??
- Nicke Löfgren
enabling 'P/T Smooth!
Pan works perfekt, but i try later Today
If you perform a timed fade is it any different? (ie. two tilt palettes, recall first then recall second over a few seconds)
- Nicke Löfgren
Ok
I try later to day
I try later to day
I've double-checked but can't find anything wrong with the personality.
- Nicke Löfgren
Ok!! Thanks
I just rigg the light for nights show!!
I check your tip
I check your tip
- Nicke Löfgren
Problem Fixt
I switch:
Marco
P/T Smooth
Thanks for Help
I switch:
Marco
P/T Smooth
Thanks for Help
