Help.....,problem TILT
Nicke Löfgren
Postby Nicke Löfgren » 03 Jul 2015, 00:23
Hey !!
Have problems with my new Martin Qvantum spot!!
Everything works perfekt but not TILT ! it just hacks !
Both in basic mode and extended mode
what can be wrong ??
need help urgently
Re: Help.....,problem TILT
Postby niclights » 03 Jul 2015, 00:52
If possible can you please provide more details? What exactly do you mean by hack?
Does enabling 'P/T Smooth' help?
Nicke Löfgren
Postby Nicke Löfgren » 03 Jul 2015, 09:18
Pan works perfekt when i rotates the wheel
When I do the same thing on tilt so moving armature not neat, more jerky / jump
Has tested the P / T speed, the same error
the problem is not in the luminaire, all have the same problem
I think it can be the personlty file??
Nicke Löfgren
Postby Nicke Löfgren » 03 Jul 2015, 09:25
enabling 'P/T Smooth!
Pan works perfekt, but i try later Today
Postby niclights » 03 Jul 2015, 09:37
If you perform a timed fade is it any different? (ie. two tilt palettes, recall first then recall second over a few seconds)
Nicke Löfgren
Postby Nicke Löfgren » 03 Jul 2015, 09:42
Ok
I try later to day
Postby niclights » 03 Jul 2015, 10:15
I've double-checked but can't find anything wrong with the personality.
Nicke Löfgren
Postby Nicke Löfgren » 03 Jul 2015, 15:45
Ok!! Thanks
I just rigg the light for nights show!!
I check your tip
Nicke Löfgren
Postby Nicke Löfgren » 03 Jul 2015, 16:26
Problem Fixt :D :D
I switch:
Marco
P/T Smooth
Thanks for Help
