I'm trying to get to grips with RDM but failing at every hurdle. I have a TTpro that doesn't have RDM compatible DMX cards, so I've tried running artnet to a Powercube to try and use RDM over artnet but that doesn't work. I've tried pluging a robe pointe into the TT via artnet and I have no joy. Tried plugging the pointe into the DMX output of the Powercube but nothing.
Where am I going wrong or should I just give up.
Looking at buying a RDM compatible artnet node but don't want to buy one if the TT doesn't support RDM over ArtNet
G
RDM
grahamrobertslx
clublights
Re: RDM
I don't know much about RDM myself but is it enabled in the fixture ? I don't know if the fixture can turn it on/off or not but check there ?
Re: RDM
As far as I am aware RDM is only supported over ArtNet.
This might be a problem with the personality. The Pointe personality doesn't currently have any RDM information in it. What happens if you use the 'Full Discover' option when connected to the Power Cube?
Re: RDM
I can confirm that Avo->Ethernet cable->Pointe does not deliver RDM information.
Avo->Ethernet cable->RDM enabled node->DMX Cable->Pointe works fine. Confirmed working on Sapphire, Expert and Mobile with Luminex Node 8 MKii.
Users browsing this forum: No registered users and 104 guests
