I have downloaded the Titan PC suite and gone through the installation, installing all elements. When I launch the simulator for the first time the first dialogue box with the different console options loads fine but when I click on for example Titan touch it never loads and I get a error message saying "Titan has encountered a problem and needs to close". I am out of ideas but I have installed it on another PC and it works just great on that one.
I have already tried the following:
Deleated and re-installed it
Turned off windows fire wall
Turned off AVG anti virus
Made sure all elements have administrator rights
Pressed loads of buttons and sworn at it
I am running it on a windows 7 acer laptop with an I5 and 8gig of memory so plenty enough for the software.
Any help greatly appreciated
Titan simulator setup error
Re: Titan simulator setup error
Pressing loads of buttons and swearing normally works. However, I wonder if this is because you don't have the required version of Microsoft .net framework installed. I believe it needs v4.0 although wondering if it might need v4.5 for Titan v8.0. Wish I could be less vague but sadly I don't know. Until someone sensible comes along and gives some more definitive advice try installing v4.0 and if that doesn't work then go for v4.5. Can't do much harm other than taking a while to download. Hopefully that will fix the problem one way or another!
Thanks for the reply but unfortunately still no joy, only thing I forgot to mention is that all the software elements icons are showing the windows shield, don't know if this rings any bells for anyone.
What happens if you click on the shield? What does it say?
