Titan simulator setup error
DaveLX1
Postby DaveLX1 » 27 Aug 2014, 20:12
I have downloaded the Titan PC suite and gone through the installation, installing all elements. When I launch the simulator for the first time the first dialogue box with the different console options loads fine but when I click on for example Titan touch it never loads and I get a error message saying "Titan has encountered a problem and needs to close". I am out of ideas but I have installed it on another PC and it works just great on that one.
I have already tried the following:
Deleated and re-installed it
Turned off windows fire wall
Turned off AVG anti virus
Made sure all elements have administrator rights
Pressed loads of buttons and sworn at it
I am running it on a windows 7 acer laptop with an I5 and 8gig of memory so plenty enough for the software.
Any help greatly appreciated
Re: Titan simulator setup error
Postby niclights » 27 Aug 2014, 23:14
Pressing loads of buttons and swearing normally works. However, I wonder if this is because you don't have the required version of Microsoft .net framework installed. I believe it needs v4.0 although wondering if it might need v4.5 for Titan v8.0. Wish I could be less vague but sadly I don't know. Until someone sensible comes along and gives some more definitive advice try installing v4.0 and if that doesn't work then go for v4.5. Can't do much harm other than taking a while to download. Hopefully that will fix the problem one way or another!
DaveLX1
Postby DaveLX1 » 06 Sep 2014, 00:14
Thanks for the reply but unfortunately still no joy, only thing I forgot to mention is that all the software elements icons are showing the windows shield, don't know if this rings any bells for anyone.
Postby niclights » 06 Sep 2014, 09:06
What happens if you click on the shield? What does it say?
