Pearl 2000 Simulator...
rogeluz
Postby rogeluz » 04 Aug 2005, 19:43
Hi...i'm from Brasil...
I need pearl 2000 simulator...somebody can help me?
What can I do to use de pearl 2004 simulator whit de wysiwyg??
Thank you!!!
Postby niclights » 04 Aug 2005, 20:22
Why do you want 2000 simulator? The software was an early version of that now released as the 2004 builds, so there is very little difference except for the graphics.
You currently cannot use the simulator with WYSIWYG
rogeluz
Why not???
Postby rogeluz » 04 Aug 2005, 21:05
Why not???
Do you know wysiwyg...I would like to configure it to use with de pearl pearl simulator...do u know if can I do? and how?
Postby niclights » 04 Aug 2005, 23:05
I was simply pointing out that there is not really any difference between the 2000 and 2004 simulator.
Yes I know WYSIWYG and as I said, no, you cannot use it with Pearl Simulator!
Phil
Postby Phil » 05 Aug 2005, 09:00
In fact, the differences between the 2000 and 2004 simulator are all in favour of the latest 2004 version.
The bugfixes between the two simulators, and pearl software running in each version are numerous, and the 2004 interface looks a little cleaner onscreen. I would strongly suggest you use the latest version since the 2000 copy doesn't simulate the 2000 software, and even if it did the 2004 software is more stable in any case!
As for WYSIWYG, at the moment, they don't support our ACDI, so it's not possible to connect the two. However, in the future we are planning on releasing a version of the simulator with DMX and ArtNet outputs which you may be able to connect to other visualisers that don't currently support the ACDI.
At the moment, you can connect the Pearl Simulator to Capture, MSD (via the ACDI) and Visualiser (by selecting "simulator" input) - I'm not aware of any other visualiser software that supports our products at the moment.
rogeluz
Postby rogeluz » 31 Aug 2005, 21:54
Thank´s...
Jasper
Postby Jasper » 11 Dec 2006, 13:49
Phil wrote:In fact, the differences between the 2000 and 2004 s
> 15 months later... Are there any updates about connecting pearl simulator with Wysiwyg? Should it be possible to convert the ACDI singal to a singal wyg does understand? By the way, I use an older versoin of wyg (10.x or 11.x)
