Hi...i'm from Brasil...
I need pearl 2000 simulator...somebody can help me?
What can I do to use de pearl 2004 simulator whit de wysiwyg??
Thank you!!!
Pearl 2000 Simulator...
Why not???
Why not???
Do you know wysiwyg...I would like to configure it to use with de pearl pearl simulator...do u know if can I do? and how?
In fact, the differences between the 2000 and 2004 simulator are all in favour of the latest 2004 version.
The bugfixes between the two simulators, and pearl software running in each version are numerous, and the 2004 interface looks a little cleaner onscreen. I would strongly suggest you use the latest version since the 2000 copy doesn't simulate the 2000 software, and even if it did the 2004 software is more stable in any case!
As for WYSIWYG, at the moment, they don't support our ACDI, so it's not possible to connect the two. However, in the future we are planning on releasing a version of the simulator with DMX and ArtNet outputs which you may be able to connect to other visualisers that don't currently support the ACDI.
At the moment, you can connect the Pearl Simulator to Capture, MSD (via the ACDI) and Visualiser (by selecting "simulator" input) - I'm not aware of any other visualiser software that supports our products at the moment.
Phil wrote:In fact, the differences between the 2000 and 2004 s
> 15 months later... Are there any updates about connecting pearl simulator with Wysiwyg? Should it be possible to convert the ACDI singal to a singal wyg does understand? By the way, I use an older versoin of wyg (10.x or 11.x)
Users browsing this forum: No registered users and 3 guests
