titan expert simulator
totalworks4u
Postby totalworks4u » 13 Apr 2014, 07:20
Mode key does not work on virtual panel. the key visually moves but do not open a system mode on small blue screen.Can not setup displays. Is there any work around this???
StijnS
Re: titan expert simulator
Postby StijnS » 13 Apr 2014, 11:11
Just like it is also possible on the real desks: Press the avo button and disk at the same time.
In the simulator you can do this by right clicking the avo button, and then left clicking the disk button.
totalworks4u
Postby totalworks4u » 13 Apr 2014, 18:35
Thanks. Done. Is anyone try to run CaptureSweden visualizer on the same PC with tinan simulator? will it work? Or it needs separate PC?
Postby niclights » 13 Apr 2014, 19:23
It will run on the same machine no problem.
