titan expert simulator
totalworks4u
Mode key does not work on virtual panel. the key visually moves but do not open a system mode on small blue screen.Can not setup displays. Is there any work around this???
Re: titan expert simulator
Just like it is also possible on the real desks: Press the avo button and disk at the same time.
In the simulator you can do this by right clicking the avo button, and then left clicking the disk button.
totalworks4u
Thanks. Done. Is anyone try to run CaptureSweden visualizer on the same PC with tinan simulator? will it work? Or it needs separate PC?
It will run on the same machine no problem.
