Changing Page of Executors
CSmithDesign
Postby CSmithDesign » 27 Feb 2014, 10:32
Is it possible to change the page of the 20 executors on the top right of the TM? So that I can get a fresh bank of executors every time I go to a new page?
Thanks in advance
Re: Changing Page of Executors
Postby niclights » 27 Feb 2014, 12:47
Yes. There are some factory macros provided to do this - 'Static Playbacks Page -1/+1/0/1/2/3'.
You can assign these to handles via show library: [Open Workspace Window]/[Show Library], select Macros filter. Press Copy, Select macro (for example 'Static Playbacks +1') and select destination handle (for example executor 20). Repeat for 'Static Playbacks -1' on executor 19. You can then use [Playback Options] to toggle the handle paging for these to locked so that they are available on every static page.
CSmithDesign
Postby CSmithDesign » 27 Feb 2014, 15:23
Great, thanks!
CSmithDesign
Postby CSmithDesign » 27 Feb 2014, 15:27
Follow up, would it be possible to get more pages? Meaning, an executor page 4, 5, 6... How would I create these macros?
Thanks again, sorry for filling up the forum.
Postby niclights » 27 Feb 2014, 16:27
You can access more pages using +/-. It is possible to create macros that go directly to other pages but it requires editing the factory macros xml file.
samdissoire
Postby samdissoire » 11 Mar 2014, 11:14
niclights wrote:Yes. There are some factory macros provided to do this - 'Static Playbacks Page -1/+1/0/1/2/3'.
I,
It's possible to do this with my pearl expert?
I try to do this with the touch wing and that didn't work...
Postby niclights » 11 Mar 2014, 18:29
No, sorry, currently it is not possible to page the physical handles on the Expert Touch Wing.
