Is it possible to change the page of the 20 executors on the top right of the TM? So that I can get a fresh bank of executors every time I go to a new page?
Thanks in advance
Changing Page of Executors
CSmithDesign
Re: Changing Page of Executors
Yes. There are some factory macros provided to do this - 'Static Playbacks Page -1/+1/0/1/2/3'.
You can assign these to handles via show library: [Open Workspace Window]/[Show Library], select Macros filter. Press Copy, Select macro (for example 'Static Playbacks +1') and select destination handle (for example executor 20). Repeat for 'Static Playbacks -1' on executor 19. You can then use [Playback Options] to toggle the handle paging for these to locked so that they are available on every static page.
CSmithDesign
Great, thanks!
CSmithDesign
Follow up, would it be possible to get more pages? Meaning, an executor page 4, 5, 6... How would I create these macros?
Thanks again, sorry for filling up the forum.
You can access more pages using +/-. It is possible to create macros that go directly to other pages but it requires editing the factory macros xml file.
samdissoire
niclights wrote:Yes. There are some factory macros provided to do this - 'Static Playbacks Page -1/+1/0/1/2/3'.
I,
It's possible to do this with my pearl expert?
I try to do this with the touch wing and that didn't work...
No, sorry, currently it is not possible to page the physical handles on the Expert Touch Wing.
Users browsing this forum: No registered users and 190 guests
