Record Palette
dim_111
Record Palette
Postby dim_111 » 09 Mar 2013, 05:27
Hi
I tryed to record normal pallette.
All done, but can't see palette legend in workspace windows.
I can recall this palette by number with no any visual approvement on screen.
Quick palette records without any problems.
Titan Mobile
Postby icke_siegen » 09 Mar 2013, 09:54
Seems you recorded the palette into the 'palette pool', without assigning it to a handle.
To assign it to a handle:
<Palette>
<your palette number>
[Assign to Handles]
[now press the button where you want the palette to go]
If you alreday have some more palettes which you want to re-assign, you may just open the Show Library window. 'Assign to Handles' is one of the context options.
For future use, when you want to create a normal palette:
- set the values
- <Palette>
- [record Palette]
- [Shared/Normal]
- now press the button where you want the palette to go (this is where you likely pressed [Store], which stores the palette without assigning it to a handle)
dim_111
Postby dim_111 » 09 Mar 2013, 10:20
Thank you!
