Hi
I tryed to record normal pallette.
All done, but can't see palette legend in workspace windows.
I can recall this palette by number with no any visual approvement on screen.
Quick palette records without any problems.
Titan Mobile
Record Palette
Seems you recorded the palette into the 'palette pool', without assigning it to a handle.
To assign it to a handle:
<Palette>
<your palette number>
[Assign to Handles]
[now press the button where you want the palette to go]
If you alreday have some more palettes which you want to re-assign, you may just open the Show Library window. 'Assign to Handles' is one of the context options.
For future use, when you want to create a normal palette:
- set the values
- <Palette>
- [record Palette]
- [Shared/Normal]
- now press the button where you want the palette to go (this is where you likely pressed [Store], which stores the palette without assigning it to a handle)
<Palette>
[Assign to Handles]
- set the values
- <Palette>
- [record Palette]
- [Shared/Normal]
