Titan mobile fix per download
bigears
Postby bigears » 04 Jan 2013, 10:46
Hello everyone .
very new to Avolites and Titan mobile . I have been trying to update the fixture personality file from the website has per the manual. I download the file to my hard drive and then run the file . I can find the file on my system under downloads . but' after restarting the software and going to patch to find the new personalitys. they are not there ? two downloads and still no luck
Can anyone tell me what I'm doing wrong . Sorry for the dum question
cheers
Postby niclights » 04 Jan 2013, 13:30
Well it should be as simple as that. To confirm, you should be downloading 'TitanPCSuiteFixtureLibrary.exe'. Once downloaded you run this which will bring up a prompt asking if you want to install. Then start the Titan software.
bigears
Postby bigears » 05 Jan 2013, 00:35
Yes thank you so it is :) Sorry late night brain dead . was looking for the impression 90 under i and not GPL :oops:
also i'm running V4.2 if i update to V6 will i lose all my shows/patch ect ect ?? i think not but don't want to start again .
cheers big ears
Postby niclights » 05 Jan 2013, 01:45
4.2 to 6.1 is a big jump and there is a risk. I would suggest running it through the interim versions just in case. ie. download and install 5, load show, save show, download and install 6, load/save and finally download 6.1 and load. Check as much as possible (preferably at each stage to be sure).
Keep a copy of the original. As a last resort you can always uninstall 6.1 and go back to 4.2.
bigears
Postby bigears » 06 Jan 2013, 02:26
yes thanks again for your advice a loaded v5 without any problems . looks like the way to go .
