Changing Gobos via Fader
chriscockrill
Postby chriscockrill » 03 May 2012, 16:09
Is there any way to program a fader to scroll though gobos on a Tiger Touch or Expert? Im really not sure why I would want to do this but was just curious if this programming was possible. Thanks!
Postby icke_siegen » 03 May 2012, 16:29
Yes, it's possible - depending on how the gobo channels are implemented in the fixture and in the library.
- record a cue with all the other stuff, dimmer on, position etc. - and Gobo@Open
- record a second cue, Fade Mode = 2, with Gobo=Raw DMX @full (or wherever the last gobo sits)
Now, fire the first cue. You can fade through the gobos with the second cue...
Which fixtures are you using?
chriscockrill
Postby chriscockrill » 03 May 2012, 16:33
Ah I see! Understood.
There is no particular fixture that I am using. A friend just said that he saw someone do that on an AVO so I was just wondering how or if it was really able to be done.
Thanks for the reply!
Users browsing this forum: No registered users and 101 guests
