How this DMX in Slot works?
ssb3883
Postby ssb3883 » 25 Aug 2010, 20:28
At the back of my there is 5Pin Xlr slot called DMX in(other than Usual 4lines). Can I know How this slot work?
Can I loop my two Avos using this slot? if yes How they work?
Postby niclights » 25 Aug 2010, 20:51
You can capture DMX data and record it in a memory using Include function.
It is not for connecting two boards together.
ssb3883
Postby ssb3883 » 30 Aug 2010, 20:06
But how does it work I mean from where I can Capture data and which memory I can Save it?
Postby niclights » 30 Aug 2010, 23:54
You capture whatever data is on the line that is connected to the DMX In and store it anywhere you want.
So, for example, you connect another console, fire a cue on that console, press Include, select DMX In, and then store that in a cue, palette or chase.
ssb3883
Postby ssb3883 » 09 Sep 2010, 19:33
Can I loop two pearls in any other way?
Postby niclights » 10 Sep 2010, 01:24
Short answer is no.
You could connect by MIDI and when you fire a playback on one console it will fire the same on the other. Theoretically. Can't imagine it being useful.
