Hello.
I have two probleme with my pearl expert
I use titan V2.
In run mode i can only use the softey as a kill fonction.
The flash and swop button have the same fonction: kill
Is it normal?
(moderation note: removed cross-post)
Thank very much.
Sorry for my english:)
i only can swop in run mode
I removed your second problem to avoid confusion since, as you pointed out, you have already posted it in a more appropriate topic.
I'm not sure what you mean by 'softkey as a kill function'.
In the key profile 'run' the blue buttons are swop (solo) and the grey buttons are flash.
There is a bug in v2.0 where, if the grey key for fixtures is defined as 'flash' and there is nothing stored on the associated handle (ie. a palette) then instead of flashing it mimics the action associated with the blue key (swop in this case).
The easiest solution is to store a palette under the fixture. This is fixed in the next version.
Note that with key profiles you can customise what the blue and grey keys do.
Thank for your reponse.
This probleme alsow come with the fixtures and dimmer when I work on run mode.
I have no probleme with the playback.
Last week i have done a show with only traditionnal dimmer. I have do my playback and parameter how the buttons work. But in the show i can't only flash directly a channel: the swop and flash work in kill mode.
Thank and sorry for my poor english:)
