Remove Fixtures from a Memory - Pearl 2004
S Preston
Postby S Preston » 03 Nov 2009, 00:15
Hey all.... I think I am doing something wrong.... I am trying to remove 2 fixtures from a memory using OFF. I activate the memory, select the fixtures, press OFF, press softkey A, press MEMORY, press the desired SWOP button for the memory I am wanting to alter.
Nothing happens OR the entire memory goes out.
Am I missing something? Any help would be appreicated....
Postby niclights » 03 Nov 2009, 01:34
Are you getting the option to merge/replace?
S Preston
Postby S Preston » 03 Nov 2009, 02:50
No, I am not getting the merge/replace option
Olie
Site Admin
Postby Olie » 03 Nov 2009, 09:19
What version of software are you running?
S Preston
Postby S Preston » 03 Nov 2009, 16:27
I am trying to get this software version... I am in Las Vegas and the console is in Detroit. So am I to assumethat the correct procedure is being used and it may be a software issue?
S Preston
Postby S Preston » 03 Nov 2009, 18:40
Just got the word... the console is running software V 1.2.2.
S Preston
Postby S Preston » 03 Nov 2009, 20:01
Got it.... Spoke with Steve in the Tenn office and he got us set. It had to do with the shape generator.... all is good. Thanks for the help!
Postby niclights » 03 Nov 2009, 21:39
If you have time it would be useful to post your solution to the problem so that others can benefit when searching in the future.
