Hi
I have a no-name Spot 575 moving head fixture and I am trying to write the Personality file for it. The problem is that the fixture is utilizes the dimmer channel for some macros. The dimmer channel values is as follows:
0-29 Shutter closed
30-39 Lamp on & reset
40-59 No function
60-69 Lamp off & reset
70-255 Dimmer intensity from 0% to 100%
How do I write this and still have the Dimmer part as HTP but preventing the fader to accidentally do a lamp on/off ?
And I suppose I must write the lamp on/off and reset as macros.
Regards Tobias
Personality file problem
If this is for .r20 then you may be in trouble. I can't think of any way to do this. I believe in the past I have suggested the possibility of assigning user curve to this channel and then defining one to only encompass the dimming range. However, I have never confirmed whether this works or whether it subsequently prevents accessing the excluded values directly with macro.
In .d4 files this is possible.
Either way you could always request this through the online library and get some head scratching at HQ.
