i hate to ask a Hog comparison...
Greg Kershaw
Postby Greg Kershaw » 15 Dec 2008, 04:46
But is there a similar fuction to "Pig + Release" to return all fixtures to a default position,colour, beam and for stopping any embedded effects/cues.
I am new to Avo and I am quite enjoying the Diamond Elite, but would like a similar function if its available.
Greg
Thanx for your time
David.Hunt
Postby David.Hunt » 15 Dec 2008, 10:17
for the d4 there is a function for returning the fixture to a set of default values. This is locate. To use it on a d4 all you need to do is select the fixtures you want to locate and then press and hold the shift key and then hit the locate button.
This will then send the default dmx values to the fixtures selected.
Tumbleweed
Postby Tumbleweed » 16 Dec 2008, 05:41
on the Pearl, you select your fixtures, hit ML Menu, then locate.
It's easier than on the Hog. (I hate the hog...LOL)
Postby niclights » 16 Dec 2008, 12:57
Actually it's easier than that. Just select fix and press the red button at the bottom of attribute bank. In Titan you can choose to locate specific attributes only, if you require.
Dan
Postby Dan » 16 Dec 2008, 17:57
niclights wrote:Actually it's easier than that. Just select fix and press the red button at the bottom of attribute bank. In Titan you can choose to locate specific attributes only, if you require.
All this talk of Titan in posts.... I assume it's now available then? How do I go about getting a copy for my Expert?
Braathe
Postby Braathe » 16 Dec 2008, 21:13
Dan wrote:All this talk of Titan in posts.... I assume it's now available then? How do I go about getting a copy for my Expert?
All this talk of Titan from Nic is becuse he is one of the lucky few who is testing Titan at the moment so the software that is released should be as much as posible free of faults.
As far as I understand once Titan is released you will need to request a CD from AVO and and they will send the upgrade to you in the post
Be glad they dont ship out a half way product but takes propper time to fix any probs!
Dan
Postby Dan » 22 Dec 2008, 02:05
Ahh, that makes sense!
The waiting isn't the problem - but with people talking about it on the forum as if it will "solve" problems is a bit confusing, as it makes it seem like its a current solution, when obviously it's not!
Postby niclights » 22 Dec 2008, 02:32
The 'problem' is solved in all currently available software. Titan merely enhances the function and I point this partly just for advance information at the time, but also for it's relevance when users search the forum in the future.
sonyboy
Postby sonyboy » 23 Dec 2008, 16:48
i read all replays (i'm working and learning in both)and all i need to say is that:hog is for stupid ones(include me)
avolites is for the man who know
it's the same when somebody ask me is martin light jockey all right.
yes it is............................................................FOR BEGINERS
do not be afraid of the light
Tumbleweed
Postby Tumbleweed » 24 Dec 2008, 07:58
Light Jockey is good for DJ's, and that's about all.
