Need help making LEDJ Slimline 9q8 work in Visualizer
rlangaard
Postby rlangaard » 07 Dec 2012, 14:36
Hi!
I'm trying to make a personality for the 9q8's so i can use them in visualizer.
Opened the file from Titan mobile in personality builder and made viz file.
Most things work, except that they always flash at a slow rate.
about 60bpm i guess..
How can i fix this?
I must add that i'm quite new to building personalities. This is my first try.
Requested the personality, but needed it quick, so decided to try myself..
Postby icke_siegen » 07 Dec 2012, 16:38
Usually the ranges in the vis file need to be adjusted manually = with a text editor. If you want, you can send me the files you created (and the manual along, if possible) by e-mail; I will try to fix it, and will comment the changes for you.
Postby icke_siegen » 07 Dec 2012, 16:49
Haven't found the Slimline manual yet. However, open the created vis file with a test editor (use a plaintext editor).
Find this section:
// Shutter
ChanRef Dimmer
    Vismode Strobe
    UseBits 1 2 3 4 5 6 7 8
    DmxOffset 2
    Mapping 0 255 30 300
End
Add some more mapping lines, e.g.
Mapping 0 0 0 0 //Shutter closed at DMX 0
Mapping 1 10 1 1 //Shutter open at DMX 1...10
Mapping 11 255 30 300 //Strobe at DMX 11...255, slow to fast
(you may of course omit my comments, including the two slashes)
Best, S.
rlangaard
Postby rlangaard » 07 Dec 2012, 17:44
thank you for quick reply
I will email you the files right now. :)
Postby icke_siegen » 07 Dec 2012, 18:01
Mail sent.
However, you have only 5 channels in your files, while the original fixture - and the Avo files - have 7 channels.
Btw., you can use the same vis file in either case. Vis doesn't support white nor macros.
rlangaard
Postby rlangaard » 07 Dec 2012, 18:18
Thank you so much for the help. :)
My viz file now works!
Let the programming begin!! :D
Postby icke_siegen » 07 Dec 2012, 18:40
Thanks for the feedback, have fun :D
