I have a question on D4 V1.4.3
I created a mode 3 cue, played it back, and pressed Swop or Flash button. Then, I pushed a playback fader down, but output is still on.
Is this a way how the mode 3 cue works?
Please let me know.
D4 Mode 3 Cue on V1.4.3
There are a couple of known issues with Mode 3 cues at the moment that can cause HTP output to be left on after the cue has been killed. They're currently awaiting fixes.
The intention of a Mode 3 cue is that you should be able to crossfade to a known state stored in that cue, and all other active cues are faded out. After killing the Mode 3 cue the effect should be a blackout (unless you fired any others after triggering the Mode 3 one).
To ensure a mode three cue runs properly when swopping or flashing it at the moment it's currently best run with the playback (or preset) fader that it was recorded onto at 0%.
