Hello, I've been running into a situation many times and I'd like to see if you've got a good idea on how to execute the programming quickly:
Suppose I have 40 MAC 301s in a line and I want to create a "push out" cue. Meaning Fixtures 19 and 20 come to full completely synchronized, then 18 and 21, then 17 and 22, etc. all the way out to the end, completing the cue in about .5 seconds.
Given the size of the rig, it's obviously time consuming to create a cue list with every step automatically following the last, and I do not want to run an effect or fixture overlap through a fixture selection because then the fixtures aren't coming up or down at the same time together like I want.
Do you have any suggestions on this? On the MA, I'd be using the MATricks for this, but that's obviously proprietary to MA. Do you have any workarounds that come to mind?
Programming Advice
CSmithDesign
CSmithDesign
CSmithDesign
Users browsing this forum: No registered users and 73 guests
