Shapes in Theatre Stack
TallPaul
Postby TallPaul » 10 Jul 2005, 19:13
Hi, I have an Avolite Pearl 2000 Desk on loan from another venue and I am having a problem when trying to program in Theatre Stack Mode. I can program static states fine, but when I have a state that includes a running shape, the shape does not get recorded. I have tried both Record Stage, and Record Programmer, but neither work. I have to plot tomorrow, can you suggest what might be wrong?
Many Thanks,
Paul
Olie
Site Admin
Postby Olie » 11 Jul 2005, 12:11
To program shapes into the Theatre Stack you must have Version 1 software or above.
You also can only record shapes that are in the programmer. It does not work with shapes that are running off the playbacks.
To record a shape into the programmer whilst in Theatre Programming.
1) Press Shape Generator [Softkey B].
2) Setup the shape you require.
3) Exit Shape Generator.
4) Select Record Menu [Softkey D].
5) Select Record Programmer [Softkey D].
You should find that the shape is recorded into the step. The fade time of the shape is the LTP fade time of the step.
Hope you get it working!
Olie
freek
shapes in theater stack
Postby freek » 20 Apr 2006, 15:39
How do you put a shape in theatre stack on the azure 2k desks?
Been struggling with this problem for some time now.
