Hello all who care.
I've built a personallity for G-lites LED Beam 90... Almost.
The wheel mapper will not hold the the assignments?
I have saved it to pesonalities Library to the File and as a seperate file.
I have started a new file and taken one from the Library and changed it.
But it still won't hold the wheel mapper?
anybody.
Wheel Mapper not holding Assiginments?
- Dereklites
- Dereklites
- Dereklites
Its kind of like I said in the origanal message.
I built a personallity from scratch it wouldn't hold the wheel mapping atts
then I tried to take a fixture from the Library that was close as could be
the the one I was building same result. Pan and Tilt are the only thing in 16 bit with a seperate 8 bit Pan and Tilt everything else is 8 bit.
as far as Mode I used 12 channel 16 bit I tried Mode 4 no good and also tried to just go everything 8 Bit.
Thats it.
Thats it.
- Dereklites
