Master Blackout - Titan Mobile V6
nrosten
Postby nrosten » 11 Aug 2012, 23:01
Hi All,
is there any easy way be it with a button / touch / fader to have a master blackout of all fixtures (moving / fixed and such) ?
ideally dont want to have to amend each program as there is loads! but not sure how doable this is .. but ideally at any point be able to hit said button / touch / fader and turn the lamps off and then have it all go back to what it was doing after its released?
Liking the V6 upgrade - big improvement.
Neil
Postby niclights » 12 Aug 2012, 00:51
Assign a Grand Master to a handle and set the key action to DBO:
- System
- [Assign Mastering]
- [Grand Master]
- Select destination handle (fader or playback workspace)
- Shift+[User Settings]
- [Key Profiles]
- [Add Profile]
- Give it a name, for example 'GM DBO'
- Select a profile to base it on. [Program] will be fine.
- Select the button/touch to shortcut to the relevant key.
- Select [DBO]
- Shift+Exit (to return directly to root menu)
- [Playback Options]
- Select Grand Master handle (*)
- [Key Profile]
- Select [GM DBO]
(* There is a bug when setting playback options for masters. The handle should highlight in red showing it is being edited. If it does not then move the handle to another location first.)
Note that we could have simply selected the GM DBO profile for global use rather than assigning it to the handle. The only problem with that would be if you are using other masters such as BPM where you might want the key action to be tap tempo.
nrosten
Postby nrosten » 12 Aug 2012, 08:29
Many Thanks, comprehensive reply as usual.
will give it a go and yes now v6 is out like the idea of a BPM master also to slow m.heads down when needed.
Neil
nrosten
Postby nrosten » 12 Aug 2012, 08:57
Hi Nic
I just did the same for the rate grand master which is also useful but one slight thing - when I assigned the rate gm to the fader it appears to go from 0 to 200% rather than 0 to 100% is this by desing or can you change the scale ? it works perfectly..
*scratch that I just found the scale in the playback options - thought I would leave this post in case anyone else needed same thing.
Neil
istrateo
Re: Master Blackout - Titan Mobile V6
Postby istrateo » 23 Jul 2015, 07:11
With Titan Mobile, using v9.0, I am unable to assign the DBO function to either the Blue Key or the Grey Key. The only options that appear are: Disabled, Selection, Flash, Latch, Tap Tempo, Nudge Up, Nudge Down.
Is this the intended behaviour? If yes, how can I assign the DBO function to a physical button on the Titan Mobile?
Postby niclights » 23 Jul 2015, 13:49
Ummm... good question!
