I'm going to be pre-programming a show on my mobile and then migrating that show to a Pearl Expert Titan and I'm wondering how that's actually going to work:
How will my pages show up on the Pearl? If I have 10 pages programmed with most (if not all) of the faders being used on each page, how is this going to translate to the pearl? Will it fill up faders 1-80 before going to the next page, or will it translate the pages exactly?
Also, what happens to the executor buttons (I use all 20) and the playbacks I have stored in the playbacks window?
Thank you in advance.
Migrating a Show from Mobile to Pearl
CSmithDesign
Crossloading playback masters will translate as follows:
PE Roller A 1A = TM/TT Page 1
PE Roller B 1A = TM/TT Page 2
PE Roller A 1B = TM/TT Page 3
PE Roller B 1B = TM/TT Page 4
PE Roller A 2A = TM/TT Page 21
PE Roller B 3J = TM/TT Page 60
Or, in other words, beginning from TM/TT Page 1, odd page numbers are the left roller on PE, even are the right. These work up through the roller facets until you reach page 21 where we return to facet A and move to roller page 2.
Executor buttons can be found in Show Library (filter assigned playbacks) as 'Static Playbacks'. Assign to new handles by selecting source in the show library followed by the destination handle.
Anything in windows will stay the same as there is no difference between consoles. The only thing you need to worry about are physical handles. Remember that you can always use the Simulator to check and edit.
DUSTINSNYDER
DUSTINSNYDER
DUSTINSNYDER
DUSTINSNYDER
I think that's the best solution and would be my choice.
I don't know the details behind the decision other than to focus exclusively on the 'touch' range (PE/TT/TM/ST). If you're not familiar with d4 Titan it is quite different - there are no workspaces for one. If you are from a TM/PE background then it would probably be a difficult transition.
That's not to say it won't be supported, potentially with bug fixes. But without software development I can't see how files will be compatible.
EmmaThompson
We do still support the D4, but we are no longer developing the software for it. The market the D4 was aimed at is basically the same market we are targeting the Sapphire Touch at, and the ST is designed around the Titan UI, so you get the same user experience whether you are using the Mobile, TT, Expert or ST.
Emma Thompson
Training and Events
Training and Events
Users browsing this forum: No registered users and 94 guests
