Hi @ all,
I would like to buy titan mobile but I have some questions for experts users.
I just have a multitouch lcd 23" monitor, it is possible to connect it and use titan on mac mini?
or other mini pc?
So I could have a complete consolle with low space.
Thanks for your advice
Carlo
Titan Mobile info
carlettodj
Hi Carlo,
Mac Mini would work, however, it's strongly recommended to run Windows in Bootcamp. No experience with virtual windows - I would never run a show from a virtual environment.
As for the Touchscreen: essentially it should work, as long as Windows recognizes the touchscreen. But the software doesn't support multitouch (even if windows does - from 7 on).
Symelighting
Hi Carlo
I have a Titan Mobile running from an Apple Mac Mini using Bootcamp. Works a treat! I did swap out the HD for a SSD so it was more flight case friendly and upgraded the ram. It used to take about 20-30 seconds to startup but now takes about 10 seconds to boot into windows 7 32bit. I have a 22" touch screen with it and yeah it has all the functions of a normal windows computer but with the build quality of an Apple product. Must stress Titan likes 32bit Windows better the 64bit. Plus the Mac Mini has four USB ports which is great as the Titan Mobile Wing takes up two USBs to work, then I have one for the touch screen and then one for a USB lamp or USB drive for transfer of show files. Hope this Helps.
Will Syme
http://www.symelighting.com
Will Syme
carlettodj
carlettodj
Yeah, All-In-One PCs are a good choice. However, the cheaper ones usually sport some Intel GMA graphic chip, and usually no secondary monitor out. Since it's scheduled for one future version of the mobile to support a second screen, some extra bucks for the proper configuration are certainly a good investment.
carlettodj
Titan PC's
I am using a Acer Z series 23" touch screen all in one PC. Works fine in 64bit with Windows 7. I have an Iilama 17" touch screen monitor which I used with Tiger Touch as a second screen perfectly well and without problems. This is connected to the Acer and displays the second screen when in PC mode fine. Once Titan Mobile supports the second screen this should work fine giving me two touch screens.
