Martin MAC Aura
frontal
Martin MAC Aura
Postby frontal » 27 Nov 2011, 22:36
Anyone got a personality file for this one? I am using Titan V5 on my Avolites Titan Mobile.
Regards,
Kurt
Norway
Regards,
Kurt Naeslund
StageWorks
Postby niclights » 27 Nov 2011, 22:41
frontal
Postby frontal » 27 Nov 2011, 23:30
Thank you very much :-)
But that personality doesnt show in the Visualiser...!?
Regards,
Kurt Naeslund
StageWorks
frontal
Postby frontal » 27 Nov 2011, 23:53
When trying to find it in the Visualiser, it doesn show.
Regards,
Kurt Naeslund
StageWorks
Postby niclights » 28 Nov 2011, 00:01
The Vis file has not been written yet. You can request it here
frontal
Postby frontal » 28 Nov 2011, 07:37
Thanks again :-)
Regards,
Kurt Naeslund
StageWorks
john rogers
Postby john rogers » 28 Nov 2011, 10:59
Hi Kurt,
This fixture is unsupported by Visualizer as it emits multiple light sources, which Vis is incapable of doing.
frontal
Postby frontal » 28 Nov 2011, 11:01
I understand, but thanks for replying :-)
Regards,
Kurt Naeslund
StageWorks
Raúl
Postby Raúl » 02 Mar 2012, 11:29
Can you make the Aura beam to be controllable from the normal profile?
I want to access the Aura channels (not beam ones) without Unfold the fixture, that's possible?
I'm talking about Titan, I think in classic Pearl it's already done...
Thanks.
Raúl Gómez
ILUMINACIÓN ALBADALEJO SL
http://www.albadalejo.com
john rogers
Postby john rogers » 02 Mar 2012, 12:38
Hi Raul,
There are other ways to select cells without using the Unfold menu. Descriptions of which can be found in this thread: http://avolitesshop.co.uk/phpBB3/viewtopic.php?t=1931
HTH
Raúl
Postby Raúl » 02 Mar 2012, 12:53
Yeah, but they're all very very bad solutions.... right now.
It will be possible to put all channels together in the 25ch mode? as I don't need to change the selection?
I want to select my Auras and have all channels at once... If I only need Aura channels then it's logical to do it as you describe on that post, but if not, too much work then.
Thanks.
Raúl Gómez
john rogers
Postby john rogers » 02 Mar 2012, 12:56
I've forwarded this topic to the fixture support team.
Postby niclights » 02 Mar 2012, 15:32
You can always add an extra mode that doesn't have cells.
Raúl
Postby Raúl » 02 Mar 2012, 15:46
niclights, I just did that and I was about to try it.
Thanks...
Raúl Gómez
Raúl
Postby Raúl » 08 Mar 2012, 11:22
I've just tried it, but the desk seems to confuse Beam and Aura channels on the output, and doesn't work good.
Can you take a look at it?
Raúl Gómez
