tiger personality update problem
Martijn
Postby Martijn » 19 Jan 2012, 10:27
I'm trying to update the personalities of the tiger (no touch) so i have the Martin MAC101 personality.
- I downloaded the Personality Library Installer 1 en 2
- run the .exe files and copy the files to a memory stick
- inserted the USB into the consol and run the Sync Fixture option
- the consol was copying files for 30/40 minutes
- done
After this, no mac 101 in the fixure librairy.
the 101 file is for sure on the USB stick.
Is there something i doing wrong??
Postby icke_siegen » 19 Jan 2012, 12:38
you sure selected the correct option when syncing? You have to select which library to sync - select the AvoCache there. I did this wrong at first.
Else, and as a quick workaround, select the thumbdrive as source when patching
Martijn
Postby Martijn » 19 Jan 2012, 12:43
that should be the problem.
tnx
Users browsing this forum: No registered users and 157 guests
