Palette creation in avolites personality builder
brad@stagelineproductions
I have read through the post but found no info on how to create palettes in the personality builder. Help anyone?
After creating the personality file, defining the attributes and such, go to the tab 'Palettes' (top-right pane), and drag the desired pattes to the 'Palettes' item in the left pane. You can adjust the actual DMX values later on.
Well, I am sure there are easier ways to add custom palettes - personally, I do not hesitate doing the fine adjustments with an text editor. But the above procedure should help you get started.
S.
S.
