Using Titan Mobile as backup console
peter.rodda
Postby peter.rodda » 25 May 2011, 08:55
Is it possible to use the Titan Mobile as a back-up to the Tiger Touch or Pearl Expert?
Now I know that the show files are compatible, so it is possible to run the same show on the different desks. I have a few questions related to this, like what does it do when you have cues and cuelists saved on some of the preset faders and you load the show up on the Mobile? Would you have to setup your original show with this in mind?
Then, would one need manually make sure that both consoles are in the same place in the show, and switch the DMX cables should the main console go down?
Is it possible to setup the Titan Mobile as a tracking/running back-up mode so that it is following the main console and will switch over into the same place should the main console go down?
Thanks for the support!
Peter
Postby niclights » 26 May 2011, 18:43
There is no tracking backup yet.
Regarding presets you can open one of the 'compatibility' workspaces (Fixtures & Playbacks/Groups & Palettes). These give you access in place with the four pages. Alternatively you can use the context menu option 'move to workspace' which will transfer all the handles to relevant windows.
Obviously you might want to ensure any cues that need fader control exist on the main playbacks.
