problem with pearl 2010
tony
Postby tony » 03 Feb 2011, 13:41
I am experiencing the following problem with my pearl 2010. In RUN mode, If I have a playback slider up,...... and while that playback is running, IF I press a FLASH for a dimmer from the top banks, the playback blacksout as long as the flash button is pressed ............ on releasing the flash button, the playback contihues as normal
What am I doing wrong, or is it my console?? I have a big gig coming up in 2 days, need urgent advice guys , Thankyou
Tony
Postby niclights » 03 Feb 2011, 14:36
Just to check, are you definitely pressing the grey button or are you pressing the blue button?
tony
Postby tony » 03 Feb 2011, 14:42
Definitely the Grey button!!
Postby niclights » 03 Feb 2011, 14:54
I'm busy with a show at the moment but there's something familiar about this. It might sound strange but try storing a palette on that key even though you are using run mode.
tony
Postby tony » 03 Feb 2011, 15:02
it happens with all the flash buttons and any playback up!! not just one
tony
Postby tony » 03 Feb 2011, 15:03
Actually had rented out my board to someone else and when it came back, it started doing this even after a WIPEALL, I am not sure if its just a setting on the board or a hardware/software problem
Postby niclights » 03 Feb 2011, 15:15
Starting to sound more like hardware. Might be worth having a look at diagnostics and see if there are any clues.
At this point I think you should email service.
tony
Postby tony » 03 Feb 2011, 16:24
I just think I will
