Pearl change list
Bm!
Pearl change list
Postby Bm! » 24 Nov 2010, 11:55
Hi guys,
Can anyone give me the change list between pearl 2000/2004/2008/2010?
Cheers.
The obvious ones between 2000 & 2004 is the look but what else? i know at some point it changed from floppy to usb was it 2008? what other changes are there?
Postby niclights » 24 Nov 2010, 14:35
As you say 2004 was the major update with things like Quick Palette, Palette Paging and a lot of bug fixes. Beyond that as far as I know it is just usb support added in 2008 builds. The release notes should contain the improvements/fixes but at the moment the main download server looks to have run away and the alternate doesn't appear to have the notes...
Bottom line if you have usb then you should be on 2008, otherwise 2004 (unless it's a very old console without extended memory).
