i only can swop in run mode
tailwip
Postby tailwip » 22 Mar 2010, 19:53
Hello.
I have two probleme with my pearl expert
I use titan V2.
In run mode i can only use the softey as a kill fonction.
The flash and swop button have the same fonction: kill
Is it normal?
(moderation note: removed cross-post)
Thank very much.
Sorry for my english:)
Postby niclights » 22 Mar 2010, 20:31
I removed your second problem to avoid confusion since, as you pointed out, you have already posted it in a more appropriate topic.
I'm not sure what you mean by 'softkey as a kill function'.
In the key profile 'run' the blue buttons are swop (solo) and the grey buttons are flash.
There is a bug in v2.0 where, if the grey key for fixtures is defined as 'flash' and there is nothing stored on the associated handle (ie. a palette) then instead of flashing it mimics the action associated with the blue key (swop in this case).
The easiest solution is to store a palette under the fixture. This is fixed in the next version.
Note that with key profiles you can customise what the blue and grey keys do.
tailwip
Postby tailwip » 22 Mar 2010, 23:39
Thank for your reponse.
This probleme alsow come with the fixtures and dimmer when I work on run mode.
I have no probleme with the playback.
Last week i have done a show with only traditionnal dimmer. I have do my playback and parameter how the buttons work. But in the show i can't only flash directly a channel: the swop and flash work in kill mode.
Thank and sorry for my poor english:)
Postby niclights » 22 Mar 2010, 23:48
As I said, there is a bug with grey button on fixtures.
Store a palette underneath and flash will work correctly on grey button in run mode.
Swop works correctly on blue button.
