Hey Folks, Im a bit of a newbie in the lighting world, I've been doing lights for a group of clubs and it's a kinda learn on your own type gig.
I have a little problem I was hoping someone could give me some tips.
I am trying to make my own page on the roller so I have taken some playbacks from another page, I pressed photocopy button before I moved them, I edited a few things in the playback and merged the memories.
The problem I am having is the when hitting the swop/Flash buttons some attributes do not get changed with the new program, ie the movement or color gets stuck from one memory to the next. Sometimes even the fixtures that I edited in the memory stay on when I pull down all the faders, I have to launch another memories from zero to get them off.
Any ideas why this might happen? I think the OS in not current.
Adam
Pearl 2000 Programming error
You need to understand HTP and LTP. As a general rule, intensities (dimmer) are HTP (highest takes precedence) and everything else (pan/tilt/colour) is LTP (latest takes precedence). Therefore for colour and positional attributes they are designed to remain until explicitly told to change.
Please have a read of the manual which will explain all this.
I also suggest you program from scratch in order to fully understand. It is more likely to confuse you trying to modify someone elses programming.
Ok Im not that new, I have read the quick start manual a few times already, I can't see what I described as being related to LTP and HTP, that should only make a difference with Dimming, not movements and colors. As soon as I move the next fader it should switch to new color and new movements.
Same with the swop buttons.
I program alot of my own stuff but was trying to use a few things I liked from the other guys...
I will have another read of the Section about LTP and HTP but I doubt that is the problem in it's entirety.
Users browsing this forum: Baidu [Spider] and 32 guests
