tiger doesn't work!
nrdgnr
tiger doesn't work!
Postby nrdgnr » 14 Aug 2009, 21:07
hi!
i've just open my console (pearl tiger) , screen has contunious waving but nothing happen.. nothing on internal display ... show is starting in 1 hour and i don't know what i have suppose to do....
Postby niclights » 14 Aug 2009, 22:38
This is already probably too late. There is a 24hr emergency support number. Hopefully it's this one:
+44 (0)7831 17 8888
Otherwise, open it up and check all connections is best advice I can give.
nrdgnr
Postby nrdgnr » 16 Aug 2009, 16:07
hi again!
we found pearl expert on repair time for broken pearl tiger but i have one question ;
on pearl tiger ; the key is run mode and desk is working takeover run mode , when i push the swop button on playbacks, movinglights are taking position without dimmer channels and i'm fading up for dimmer channels.. (cue) , but i can't working like this on pearl expert.i'm pushing swop button but nothing happen... there is some settings about this??
thanks
Postby niclights » 16 Aug 2009, 18:20
I did not know you could preload with swop.
One solution is to lower flash master to zero and use grey playback button.
nrdgnr
Postby nrdgnr » 18 Aug 2009, 03:39
Hmm thanks for solution but this is long way then other.. there is no way to using preload with swop button?? pearl tiger has this function but expert doesn't , why? :?:
