titan remote on iPhone
kloas
Postby kloas » 20 Apr 2009, 17:01
Does anyone know how to get the remote application on an iPhone?
Postby niclights » 20 Apr 2009, 18:02
Software should already be installed. I can't find a document at the moment.
Basic idea is connect wireless router, set Expert IP address (using options in System menu or via standard Windows config), in Ipod Safari use URL http ://<console IP address>/remote/ On console System menu use 'pair new device'. Enter code when Ipod requests.
If you have problems first check that you have comms between Ipod and router by browsing to its address (see router manual) which usually takes you to router setup page. Similarly check console can see this.
Note that I have found some problems in booting console with the router connected and so you might be best keeping unplugged until up and running.
HTH
kloas
Postby kloas » 21 Apr 2009, 17:23
Thank You. It's working now. It was the /remote addition in the address-bar.
Users browsing this forum: No registered users and 127 guests
