Azure 2000 Tips?
galaxyshow
Azure 2000 Tips?
Postby galaxyshow » 12 Oct 2004, 07:35
Does anyone have some tips to work on Azure?
Anything practical to spend time?...
Olie
Site Admin
Postby Olie » 12 Oct 2004, 10:23
It is always a good start to read the manual. You will find as well as describing the operation of the desk it also contains tips on good programming practice.
galaxyshow
Postby galaxyshow » 12 Oct 2004, 10:43
Hi, it's what i did.
I know the manual and know how the Azure Works.
But sometimes, we can find some tips to work faster, or to create a special effect... and it's not explain in the manual, could just be discovered by using the desk.
Regards,
Olie
Site Admin
Postby Olie » 13 Oct 2004, 11:02
Great to hear that you have read the manual. The reason I mentioned it is that you would be amazed at the number of people who ring us up with questions that are answered in the manual or make simple mistakes that could have been avoided.
As I have never used an Azure to program a show, I am probably not qualified to answer your post but I hope someone out there comes up with some good tips for you!
Mikeyray
azure 2000 tips?
Postby Mikeyray » 14 Jan 2005, 16:03
Spend the time to palette properly by using the masking then its a lot easier to busk in yuour vertical columns of playback buttons think which ones you want to use at the same time so you can move them next to each other as there can only be one running per verical column
thats all i can think of for now
have fun
